pic 16f877A this code not working
damilarem
Joined Aug 5, 2017
41
help on this
sbit LCD_RS at RE0_bit;
sbit LCD_EN at RE2_bit;
sbit LCD_D4 at RD4_bit;
sbit LCD_D5 at RD5_bit;
sbit LCD_D6 at RD6_bit;
sbit LCD_D7 at RD7_bit;
sbit LCD_RS_Direction at TRISE0_bit;
sbit LCD_EN_Direction at TRISE2_bit;
sbit LCD_D4_Direction at TRISD4_bit;
sbit LCD_D5_Direction at TRISD5_bit;
sbit LCD_D6_Direction at TRISD6_bit;
sbit LCD_D7_Direction at TRISD7_bit;
// End LCD module connections
void main()
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
Lcd_Out(1,1,"Hello World"); // Write text'Hello World' in first row
jayanthd
Joined Jul 4, 2015
945
help on this
void main()
while(1); is missing. PIC will restart repeateadly. You will see a blank LCD.
Add while(1); loop at the end of the code before closing the main() loop.
hexreader
Joined Apr 16, 2011
619
Op is using mikroC, where end loop is added automatically. Does no harm to put a while(1) loop, but not actually necessary for this compiler
jayanthd
Joined Jul 4, 2015
945
Which version of mikroC PRO PIC adds while(1); loop automatically. I have been using mikroC Compilers since 5 years and when I omit the while(1) loop the device resets after reaching the end of main() function.
hexreader
Joined Apr 16, 2011
619
I have believed it to be the case for the 7 years that I have been using microC, but I must admit that I always include while(1) just for portability. Not many programs end anyway.
Looks like some testing is needed to prove it one way or the other, but I am away from my PIC gear for a few days, so it will have to wait.
EDIT: - did try compile of very simple program and found a goto $+0 statement at the end of the listing, which seems to support my theory I think.
_main:
;junk.c,2 :: void main() {
;junk.c,3 :: CMCON = 0x07;
0x0016 0x3007 MOVLW 7
0x0017 0x1683 BSF STATUS, 5
0x0018 0x1303 BCF STATUS, 6
0x0019 0x009C MOVWF CMCON
;junk.c,4 :: TRISB = 0x00;
0x001A 0x0186 CLRF TRISB
;junk.c,5 :: PORTB = 0x55;
0x001B 0x3055 MOVLW 85
0x001C 0x1283 BCF STATUS, 5
0x001D 0x0086 MOVWF PORTB
;junk.c,7 :: }
L_end_main:
0x001E 0x281E GOTO $+0
; end of _main
damilarem
Joined Aug 5, 2017
41
help on this
void main()
i have tried it still not working but i used pic16f877A and i used the port E for the LCD in which is an AD.. so any help to turn the AD off so i can used for my LCD
jayanthd
Joined Jul 4, 2015
945
For PIC16F877A to turn off the Analog functions on all pins you have to set
Code:
ADCON1 = 0x8F;
Also you need before
Code:
LCD_Init();
these
Code:
TRIAD = 0x00;
TRISE = 0x00;
@hexreader
I don't code in asm. I have used C code and it resets the PIC. I will make video of hardware (EasyPIC v7) resetting the PIC when while(1); loop is absent. I will update the thread after I make the video and upload it.
damilarem
Joined Aug 5, 2017
41
Code:
ADCON1 = 0x8F;
Code:
LCD_Init();
these
Code:
TRIAD = 0x00;
TRISE = 0x00;
@hexreader
THANKS JAYANTHD I AV TRIED D CODE AND IT WORKS
CAN YOU HELP ME WITH USING LOADCELL AND PIC?
jayanthd
Joined Jul 4, 2015
945
To write code I want to know what is the max mV your Load Cell gives and what is the max gms or Kgs your Load Cell measures. I will then write a code for you using PIC16F877A with 4 MHz Crystal.
Open a new thread regarding your weighing scale requirement. I will continue the weighing scale conversation there.
hexreader
Joined Apr 16, 2011
619
@ damilarem
Sorry for taking your thread off-track a little. Hopefully the discussion is of interest just the same.
@jayanthd
My code was in mikroC, which produced a listing file after compilation.
Attached is a project folder which I believe proves my theory to be the correct one....
Thank you for all of the help that you give to others :)
jayanthd
Joined Jul 4, 2015
945
@ damilarem
@jayanthd
@hexreader
Ok. I will test your project on easypic v7 and update the thread.
damilarem
Joined Aug 5, 2017
41
is not shouting is just to make u know that what u assked me to do have been done... the name of the thread is "weight scale requirement" thanks
jayanthd
Joined Jul 4, 2015
945
If you type in all caps then it means you are shouting.
I could not find the thread "weight scale requirement".
damilarem
Joined Aug 5, 2017
41
never knew the caps meant someting like that sorry... i just coppy and paste this from the thread i made a mistake ... this is the name "
weighing scale requirement"
jayanthd
Joined Jul 4, 2015
945
Why don't you provide the link for the "Weighing Scale requirement" thread instead of providing the thread name ?
