Can any test be performed to know if the pcb is functional?Er, well, sorry but without knowing what the pcb is and knowing the circuit and purpose, probably not.
The whole pcb is covered, so diodes, resistors are also not available.Yes, It is possible to test PCB whose one end is covered. Check this:
http://www.thomasnet.com/articles/automation-electronics/testing-pcb-components
Or you can also do testing from some PCB manufacturer.
PCBs for an MRI are likely coated to prevent the metal parts from vibrating in the magnetic field and causing distorting in the final image, or, they are covered in case anything comes loose so they don't fly out and stick to the magnet. (Remember, the docs always checks the eyes of machinists and mechanics for metal fragments because the magnetic field can rip them out in a more dramatic fashion than they were inserted.By covered i mean it has foam all over it, and so no components nothing can be seen or tested. So how is electrical tests done? Any way to check the PCB with only one end?
What did the manufacturer tell you when you called their technical support team with this question?Its tested and given to us, but i am an intern and i need to find a way in which i can test the pcb. The pcb has one wire sort of thing coming out of it, and using that wire i need to find a way to test that PCB.
Also can frequency be given(applied) to a PCB?
I am about to go off on you so if you don't want to hear it - quit reading now.Its tested and given to us, but i am an intern and i need to find a way in which i can test the pcb.
To test a PCB assembly you create some sort of test fixture that makes contact with all necessary connectors/test points and tests the assembly as thoroughly as possible to ensure all functions work as they should.Its tested and given to us, but i am an intern and i need to find a way in which i can test the pcb. The pcb has one wire sort of thing coming out of it, and using that wire i need to find a way to test that PCB.
If the board can operate from the single edge it can be tested from the edge.Can any test be performed to know if the pcb is functional?
