PCB USB pin out
Icanmakeit67
Joined Sep 23, 2018
210
I have been searching and using this in various forms to find what is connected to what pin for an hour now and I’m getting nowhere. Lots of pics, dimensions, places to buy, etc but no connection information
“schematic pin layout of pcb mount, mini usb, type b, 5 pin, 90 degree, dip, pcb mount”
IMG_0343.jpegHelp please….
MrSoftware
Joined Oct 29, 2013
2,273
You want to make sure what was posted matches the exact part that you're using. The safest approach is to get the datasheet for the exact part number that you purchased. That will tell you what goes where for that specific part. The pin locations inside the plug part of the connector are standard per the USB spec, but the arrangement of the pins that go through the PCB are not specified in the spec and could vary between parts.
