PCB Lab
engr_david_ee
Joined Mar 10, 2023
364
Hello, we are assessing the investment required to establish an in-house PCB manufacturing and assembly facility capable of producing 4- to 8-layer printed circuit boards.
The target manufacturing specifications are:
  • Minimum trace width: 0.1 mm
  • Minimum trace clearance: 0.1 mm
  • Minimum drilled hole size: 0.3 mm
  • Solder mask application
  • Finished multilayer PCBs (4–8 layers)
In addition to PCB fabrication, the facility should support complete PCB assembly, including:
  • Automated pick-and-place for SMT components
  • Reflow soldering
  • Component mounting and assembly
We would like to understand:
  • What equipment and machines are required to support the entire manufacturing and assembly process.
  • How many machines would typically be needed for a new facility with these capabilities.
  • The estimated cost of each major machine and the overall capital investment required.
  • Any additional infrastructure, inspection, testing, or environmental requirements that should be considered.
We are seeking a high-level cost evaluation and equipment road-map for establishing a new PCB manufacturing and assembly lab capable of meeting the specifications above. Any guidance based on practical industry experience would be greatly appreciated.
panic mode
Joined Oct 10, 2011
5,196
i don't think anyone here has been through process of selecting and procuring sich machines.
maybe watch the video and pay attention.
for example:
which gives you search term and immediate result : https://www.abletek.com.tw/
of course that is just one piece of the puzzle. you can watch few more such videos to capture additional machine labels.
once you know few players, you can ask them who makes other machines....or... why not ask AI and explain what exactly you need (volume, specs, etc.)?
To compete directly with mass-production giants like PCBWay and JLCPCB, you are looking at establishing a high-volume, highly automated, smart mega-factory. Benchtop machines are indeed "toys" in this context. True mass manufacturing relies on multi-ton industrial workhorses integrated into continuous, conveyor-driven conveyor systems. [1, 2, 3]
The primary business model of those companies relies on panelization and maximum throughput. To achieve the required economy of scale, a facility must be equipped with specific heavy machinery, sourced from specialized global manufacturers.
1. High-Speed Inner Layer & Direct Imaging (LDI)
In mass manufacturing, traditional film masks are obsolete because they slow down production changes. Factories require automated Laser Direct Imaging (LDI) systems that dynamically project Gerber files onto panels flying down a conveyor belt.
  • Laser Direct Imaging (LDI) Machine: Orbotech (KLA) (such as the Paragon or Nuvogo series) or DelphiLaser are the industry standards. These systems load stacks of panels automatically, scan registration marks via CCD cameras, and image outer/inner layers in seconds with sub-micron precision.
  • Continuous Chemical Processing Lines: Companies like Schmid Group or Atotech build massive, 30-meter-long chemical conveyor systems. Panels are fed continuously into one end and pass through automated development, alkaline etching, and stripping (DES lines) without any manual handling. [1]
2. Multi-Tier Vacuum Lamination Systems
For multi-layer boards, a factory cannot use single-opening manual presses. Mass production requires multi-daylight (multi-tiered) fully automated press lines.
  • Automated Lamination Press Lines: BÜRKLE GmbH (such as their LAMV thermal oil-heated press systems) and Cedal are the primary global suppliers. [1, 2]
  • The Scale: These systems feature 6 to 12 automated "daylights" (slots) stacked vertically. Robotic load/unload elevators automatically slide heavy steel cassettes (containing stacks of 20–50 PCB panels separated by stainless steel plates) into the press simultaneously, pulling a deep vacuum under tons of hydraulic force.
3. Multi-Spindle CNC & UV/CO2 Laser Drilling
Drilling thousands of micro-vias and standard through-holes rapidly requires massive, heavy-base multi-station drill rigs.
  • Multi-Spindle CNC Mechanical Drills: Schmoll Maschinen (distributed in North America via Schmoll America) and Excellon dominate this market. A production-grade drill machine has up to 5 or 6 independent spindles running on magnetic levitation linear motors at speeds up to 300,000 RPM, drilling multiple panels simultaneously with automatic tool-changing carousels.
  • Laser Drilling Systems (HDI Vias): To manufacture advanced multi-layer smartphones or high-density interconnect (HDI) boards, mechanical bits cannot cut tiny micro-vias. You need automated CO2/UV hybrid laser drillers from companies like Mitsubishi Electric or ESI (MKS Instruments). [1, 2, 3]
4. Continuous Electroplating & Wet Chemistry Tanks
To establish a fully functional shop, massive chemical lines are mandatory to drop copper into the drilled holes to connect layers. [1]
  • Vertical Continuous Plating (VCP) Systems: Fabricated by companies like Pal Galv技術 (Pal) or Atotech, these machines act like automated gantry cranes. They automatically pick up large racks of panels and dip them rhythmically across massive arrays of chemical copper-sinking and electroplating tanks.
5. Automated Quality Control & Final Profiling
A high-throughput factory cannot survive manual testing. Inspection must be fully automated to keep up with the output of the etching lines.
  • Automated Optical Inspection (AOI) & Electrical Testing: Camtek and Orbotech manufacture high-speed AOI machines that scan both sides of an etched layer in seconds, flagging trace defects using AI.
  • Flying Probe & Dedicated Grid Testers: For electrical verification, machines from Hioki or ATG Luther & Maelzer utilize multi-headed flying probes to test trace continuity, or massive "bed-of-nails" pneumatic fixtures for instant checking of high-volume runs.
  • Industrial Rout/Score Machines: To slice individual circuits out of large production panels at speed, factories use automated V-scoring and routing machinery from Schmoll or Pluritec. [1, 2]
Buying Channels for Industrial Scale
You cannot buy these machines on standard e-commerce sites; they are treated as capital expenditure procurement.
  • Factory Direct (New Machinery): For a brand new facility, you hire an engineering firm or work directly with the enterprise sales arms of Schmoll America, Bürkle, or Schmid. They will design the entire line, layout the facility's pneumatic, water filtration, and chemical exhaust lines, and install the machines.
  • Industrial Auctioneers & Brokers: Setting up a brand-new factory requires tens of millions of dollars. To offset costs, startup fabricators often use asset liquidation brokers like PCBEquipment.com, EquipNet, or Sigma Equipment to buy late-model multi-spindle drills, BÜRKLE presses, and exposure lines from consolidated or bankrupt electronics manufacturing plants. [1]
lichurbagan
Joined Jul 4, 2025
135
I think the production volume is probably the most important factor here.
In my experience, many companies find it more practical to outsource PCB fabrication and focus their in-house investment on assembly, testing, and validation. A modern SMT assembly line can be established for a fraction of the cost of a full multilayer PCB fabrication facility while still providing much greater control over production schedules and product quality.
I'd be curious to know the target production volume. Are you planning for prototype quantities, a few thousand boards per month, or true high-volume manufacturing? The answer can easily change the recommended investment by an order of magnitude.
For the specifications you listed, you are no longer talking about a "PCB lab". You are describing a small commercial PCB manufacturing plant. You're talking about scopes similar to PCB fabrication and assembly companies like NextPCB or JLC etc, even though your production scale may be smaller. A complete multilayer PCB facility requires many specialized manufacturing systems.
Required fabrication equipment includes imaging, drilling, plating, lamination, etching, routing, inspection, and testing.
Assembly requires stencil printing, pick-and-place, reflow, AOI, X-ray, and testing. One machine per process usually suffices initially. Two drilling machines improve throughput and redundancy. There must be two AOI systems to reduce inspection bottlenecks. Utilities include compressed air, DI water, chillers, nitrogen, and ventilation. Chemical processing demands wastewater treatment and fume scrubbers. Climate control and ESD protection are essential.
Quality laboratories need microscopes and plating measurement instruments. Typical staffing should be approximately 100 employees. Facility size ranges should be around 5000 square meters. Overall investment must be minimum 20 million USD. Many manufacturers outsource bare PCBs initially. They establish in-house SMT assembly first.
