pcb and box connectors
RodneyB
Joined Apr 28, 2012
698
I am trying to find what pcb connectors that are best used and available.
Firstly I want to connect a 800 mAth ni-ion battery pack to a pcb with a suitable socket and plug.
Secondly I want a suitable mains plug and socket for a maximum of 1 amp. That can be connected into a plastic housing.
Lastly a suitable pcb mount socket that can also be secured to the plastic housing and then a plug
30,672
Search Digikey for Barrel Connectors for the battery.
The mains plug would be a type available to where you are located, unless you want to use, and have the N.A. style?
jpanhalt
Joined Jan 18, 2008
11,087
For battery connections, I use MPA-100 style connectors (not just TE), with orientation but no lock. Here's the female: http://www.digikey.com/product-search/en?KeyWords=WM2000-nd&WT.z_header=search_go
For connection to the outside world, I use a barrel power connector like Max mentioned. I prefer the switched connectors. The ring connection is switched. You can use that to isolate the battery from the rest of the circuit for charging, or in very small designs, I use it as the on/off switch too. With plug installed, it is off. With plug removed, it is on.
John
hspalm
Joined Feb 17, 2010
201
For mains connection I wouldn't sidetrack from the IEC standard plugs that "everyone" expects to find in products these days. You can find them as panel mount or pcb mount, they are cheap and you have a cable for it already laying around. Either these or solder wires directly to the PCB using cables glands to feed through the enclosure. I think you can also buy power cords where the pigtail end have a moulded strain relief that fits in a slot you make in you enclosure.
Look at C5/C6, C7/C8 and C13/C14
http://en.wikipedia.org/wiki/IEC_60320
