Pause in UART Transmitted Values
Harnee15
Joined Sep 14, 2015
24
I am working with dspic33fj128mc804. UART used to send values from the PCB to the computer., transmits all the values but there is a tiny pause between the readings. I am sampling data at 8KHz . As the data is time critical I dont want to loose any values.
Could anyone please suggest something for this problem?
Many Thanks!!
Harnee15
Joined Sep 14, 2015
24
Thank you very much! Below is my code.
C:
#define FIFO_SIZE 656
#define FIFO_MASK (FIFO_SIZE-1)
#define  MAX_CHNUM                7        // Highest Analog input number in Channel Scan
#define  SAMP_BUFF_SIZE            8        // Size of the input buffer per analog input
#define  NUM_CHS2SCAN            8        // Number of channels enabled for channel scan
unsigned int BufferA[8]__attribute__((space(dma)));
unsigned int BufferB[8]__attribute__((space(dma)));
Used to set operating speed and default port directions along with setting
remappable peripherals
void setupPIC(void)
        AD1PCFGL = 0xff00;
        CLKDIV=0;                    //reset DOZE
        //Setup for 7.37MIPS operation (internal FRC is 7.37MHz). To get mips, we need to x2 the OSC frequency
        PLLFBD=30;                    //32*(7.37/2)=117.92MHz
        CLKDIVbits.PLLPOST = 3;        //M=16, N1=2, N2=8
        CLKDIVbits.PLLPRE=0;        //Fosc = 7.37M*32/(2*8)=14.74MHz
        OSCTUN = 0;
        RCONbits.SWDTEN = 0;        //Disable watchdog timer
        __builtin_write_OSCCONH(0x01);        //Initiate Clock Switch
        __builtin_write_OSCCONL(0x01);        //Start Clock Switch
        while(OSCCONbits.COSC != 0b001);    //Wait for clock switching
        while (OSCCONbits.LOCK != 1);        //Wait for PLL to lock
        //Port mappings
        __builtin_write_OSCCONL(OSCCON & ~(1<<6));
        //inputs
        RPINR18bits.U1RXR = 20;    //txdto Pin RP19
        //outputs
        RPOR9bits.RP19R = 3;   // TXD of pic to RXD of UART(RP19)
        RPOR4bits.RP9R = 0x8;   //SCK to Pin RP9
        RPOR11bits.RP22R= 0x7; // SDO to Pin R22
        __builtin_write_OSCCONL(OSCCON | (1<<6));
        //Setup port directions
        LATA = 0x0000; TRISA = 0x0003;
        LATB = 0x2860; TRISB = 0x006f;
        LATC = 0x0100; TRISC = 0x0013;
        // Writing 0 means line On is pulled to ground
        B1L1=0; B1L2=0;
        B2L1=0; B2L2=0;
        B3L1=0; B3L2=0;
        B4L1=0; B4L2=0;
        //initializing resistance values
        res1=0x000;
        res2=0x000;
        res3=0x000;
        res4=0x000;
          // For random number generation
        max= 30;
        min= 10;
        range= max-min+1;
        // Set up Timer for Temperature Sensor. Prescaler 1:256; PR4 Preload = 57580; 2 sec
          PR4    = 57580;
        T4CON    = 0x8030;
        TMR4 = PR4>>1;
        _T4IE    = 0;
        _T4IF    = 0;
        // Set up Timer for schedule. Prescaler 1:256; PR3 Preload = 28790 for 1 sec;
        TMR2 = 0x0000;
        PR2    = 4999;
        T2CON    = 0x8000;
        _T2IE    = 0;
        _T2IF    = 0;
        //Timer 3 for ADC trigger
        TMR3 = 0x0000;
        T3CON    = 0x8000;
        PR3 = 4999; // Trigger ADC1 every  for 800Hz
        IFS0bits.T3IF = 0; // Clear Timer 3 interrupt
        IEC0bits.T3IE = 0; // Disable Timer 3 interrupt
        T3CONbits.TON = 1; //Start Timer 3
Initialize ADC
void initadc(void)
    AD1CON1bits.FORM = 0;        // Data Output Format: Integer
    AD1CON1bits.SSRC = 2;    //  GP Timer3 starts conversion
    AD1CON1bits.ASAM = 1;        // ADC Sample Control: Sampling begins immediately after conversion
    AD1CON1bits.AD12B = 1;        // SHEN : 12-bit ADC operation
    AD1CON2bits.CSCNA = 1;        // Scan Input Selections for CH0+ during Sample A bit
    AD1CON2bits.CHPS  = 0;        // Converts CH0
    AD1CON3bits.ADRC = 0;        // ADC Clock is derived from Systems Clock
    AD1CON3bits.ADCS = 65;        // ADC Conversion Clock Tad=Tcy*(ADCS+1)= (1/7.37M)*64 = 1.6us (625Khz).
    AD1CON1bits.ADDMABM = 1;     // 1= Conversion order mode and 0 is DMA buffers are built in scatter/gather mode
    AD1CON2bits.SMPI    = (NUM_CHS2SCAN-1);    // 8 ADC Channels are scanned
    AD1CON4bits.DMABL   = 0;    //shen : Each buffer contains 1 word
    AD1CSSLbits.CSS0=1;
    AD1CSSLbits.CSS1=1;
    AD1CSSLbits.CSS2=1;
    AD1CSSLbits.CSS3=1;
    AD1CSSLbits.CSS4=1;
    AD1CSSLbits.CSS5=1;
    AD1CSSLbits.CSS6=1;
    AD1CSSLbits.CSS7=1;
    AD1CHS0=0;
    IFS0bits.AD1IF   = 0;        // Clear the A/D interrupt flag bit
    IEC0bits.AD1IE   = 0;        // Do Not Enable A/D interrupt
    AD1CON1bits.ADON = 1;        // Turn on the A/D converter
Initialize DMA
void initDma0(void)
    DMA0CONbits.AMODE = 0;            // Configure DMA for Register Indirect Mode
    DMA0CONbits.MODE  = 0;            // Configure DMA for Continuous Ping-Pong mode disabled
    DMA0PAD=0x0300 ;                //shen : Point DMA to ADC1BUF0
    DMA0CNT = (SAMP_BUFF_SIZE*NUM_CHS2SCAN)-1;
    DMA0REQ = 13;                    // Select ADC1 as DMA Request source
    DMA0STA = __builtin_dmaoffset(&BufferA);
    DMA0STA = __builtin_dmaoffset(&BufferB);
    IFS0bits.DMA0IF = 0;            //Clear the DMA interrupt flag bit
    IEC0bits.DMA0IE = 1;            //Set the DMA interrupt enable bit
    DMA0CONbits.CHEN=1;                // Enable DMA
unsigned int DmaBuffer = 0;
_DMA0Interrupt()
void __attribute__((interrupt, no_auto_psv)) _DMA0Interrupt(void)
    if(DmaBuffer == 0)
ProcessADCSamples(BufferA[0]);
        ProcessADCSamples(BufferA[1]);
        ProcessADCSamples(BufferA[2]);
        ProcessADCSamples(BufferA[3]);
        ProcessADCSamples(BufferA[4]);
        ProcessADCSamples(BufferA[5]);
        ProcessADCSamples(BufferA[6]);
        ProcessADCSamples(BufferA[7]);
    else
        ProcessADCSamples(BufferB[0]);
        ProcessADCSamples(BufferB[1]);
        ProcessADCSamples(BufferB[2]);
        ProcessADCSamples(BufferB[3]);
        ProcessADCSamples(BufferB[4]);
        ProcessADCSamples(BufferB[5]);
        ProcessADCSamples(BufferB[6]);
        ProcessADCSamples(BufferB[7]);
    DmaBuffer ^= 1;
    IFS0bits.DMA0IF = 0;        // Clear the DMA0 Interrupt Flag
void ProcessADCSamples(unsigned int AdcBuffer)
    //check=1;
    adResults[adChannelCounter]= AdcBuffer;
    adChannelCounter++;
//    adChannelCounter&=0x7;                     //Allows 0-7
    AD1CHS0=adChannelMap[adChannelCounter];    //set the channel
    if (adChannelCounter==7)        //rolled over, to have 8 samples
    shouldWriteResults = 1;        //set flag.
adChannelCounter=0;
//check=1;
Turns a numeric 0-F to ASCII 0-9 and A-F
unsigned int nibbleToHex(int v)
        v&=0xf;
        if (v>9) return (v+'A'-10); else return v+'0';
Convert ascii hex 0-F to int 0-F. Returns -1 if conversion not possible
int hexToNibble(char v)
        if (v>47 && v<58)  return (v-48); else
        if (v>64 && v<71)  return (v-55); else
        if (v>96 && v<103) return (v-87); else return -1;
UART Set UP
void initUART()
        txFIFOtail = txFIFOhead = 0;
    U1MODE=0;
//    U1MODEbits.BRGH = 1;
    U1BRG=3;            //Baud Rate 1574400
    U1MODE = 0x8800;    //EN, no flow control, no BRGH
    U1STA = 0x0400;        //only TXEN
Process UART FIFOs
void processUART()
        char dummy=0;
        U1STA&=0xFFFD; //lear the OERR bit
        if (_U1RXIF)
                dummy = U1RXREG;
                _U1RXIF = 0;
        //echo back //uartWriteByte(dummy);
                if (dummy!=0x0d) //% 0xd 0xa  is the ending of the line
                        if (uartCMDpos<16)
                                uartCMD[uartCMDpos++]=dummy;
                            } else
                                processUARTcmd();
                    } else
                            processUARTcmd();
     if (!U1STAbits.UTXBF)
                if (txFIFOtail != txFIFOhead)
                        U1TXREG = txFIFO[txFIFOtail];
                        txFIFOtail = (txFIFOtail + 1) & FIFO_MASK;
unsigned int portValues[5];
void processUARTcmd()
        int i, dummy, wasError;
        //    unsigned int newOutput;
        if (uartCMDpos==5)
                //    uartWriteString("!OK - applying values\r\n");
                wasError=0;
                //take each letter from uartCMDpos, must be 0-9, A-F. if okay, apply to relevant output. if not okay, break out and say so
                for (i=0; i<5; i++)
                        dummy = hexToNibble(uartCMD[I]);
                        if (dummy!=-1) portValues[I]=dummy; else { wasError=i+1; break; }
                if (wasError)
                        uartWriteString("!ERROR - expected 5 HEX values\r\n");
                else
                        LATB&=0x0FFF; LATB|=(portValues[4]<<12);
            } else uartWriteString("!ERROR - must be 5 letters followed by \\r\\n\r\n");
    uartCMDpos=0;
    uartCMD[0]='\0';
Writing to UART
Sending a Byte
void uartWriteByte(unsigned int v)
        txFIFO[txFIFOhead] = v & 0xFF;
        txFIFOhead = (txFIFOhead+1) & FIFO_MASK;
Send an Int, LSB first
void uartWriteInt(unsigned int v)
        uartWriteByte(nibbleToHex(v>>4));
        uartWriteByte(nibbleToHex(v));
        uartWriteByte(nibbleToHex(v>>12));
        uartWriteByte(nibbleToHex(v>>8));
Send a word, LSB first
void uartWriteShort(unsigned char v)
Send a Decimal, LSB first
void uartWriteDecimal(unsigned int v)
        unsigned int a=v/10000; char lead=0;
        if (a)       { uartWriteByte('0'+a); lead=1;  v-=a*10000; }
        a=v/1000;
        if (a||lead) { uartWriteByte('0'+a); lead=1;  v-=a*1000; }
        a=v/100;
        if (a||lead) { uartWriteByte('0'+a); lead=1;  v-=a*100; }
        a=v/10;
        if (a||lead) { uartWriteByte('0'+a); lead=1;  v-=a*10; }
        uartWriteByte('0'+v);
Write New Line 0x0d 0x0a values
void uartWriteNL(void)
        //uartWriteByte(0x0d);
        uartWriteByte(0x0a);
Writes a string into the txFIFO_USB
void uartWriteString(const char* v)
        while (*v) uartWriteByte(*v++);
Initialize DAC
void initDACs(void)
        TRISB&=~0x4010;
        DAC1CS=DAC2CS=1;
        _SPI1IF = 0; // Clear the interrupt flag
        _SPI1IE = 0; // Disable the interrupt
        //Initialize SPI
        SPI1CON1=0x073e; //16bit, master, prescale 4, CKP0 CKE1 SMP 1
        SPI1STAT=0x8000; //enable SPI
        DAC1CS=0;DAC2CS=0;
        SPI1BUF = 0x3000;    //Set output of A to 0V
        while(!_SPI1IF); //wait until SPI has finished
        _SPI1IF = 0;
        DAC1CS=DAC2CS=1;
        SPI1STAT &=~0x40;
        DAC1CS=0;
        DAC2CS=0;
        SPI1BUF = 0xb000; // Set output of B to 0V
        while(!_SPI1IF); //wait until SPI has finished..****
        _SPI1IF = 0;
        DAC1CS=DAC2CS=1;
        SPI1STAT &=~0x40;
Function to set values on the DAC
void channelSetDACtwo(int v, int ch)
        unsigned int sendData;
        if(ch>3) return;//wrong values
        if(ch &1)
                sendData= 0x3000 | (v & 0xfff);
        else
                sendData= 0xb000 | (v & 0xfff);
        if (ch <2) DAC1CS=0; else DAC2CS=0;
        SPI1BUF=sendData;
        _SPI1IF = 0;
        DAC1CS=DAC2CS=1;
        SPI1STAT &=~0x40;//same like in init.... ****
        spiReady=1;
Moderators note: Please use code tags for pieces of code
