I've been working on a very simple circuit to mix audio from 2 audio sources passively. I've looked into both active and passive circuits and for the sake of simplicity, I'm working on a passive circuit. I'd rather not have to deal with adding a power source if I don't have to. It's 2 inputs and having to boost the signal a little on both inputs is not a big deal.
I have this circuit right now:
If I were to choose a lower resistor value for the 100ohm resisters, say 20ohm, should I be worried about damage to either source if my headphones are not plugged in and the sources are still driving the line or even if the headphones are still plugged in? Should I expect to see more power usage with the lower resistor values?
