I have IGBT 40n60 and mosfet 20n60 , can I connect both in parallel in left or right Arm of H-Bridge inverter in high frequency pulsed =18khz?
why ? if they open and close simultaneously ,from source to drain and other from emitter to collectorShort answer is no, they will not current share in any meanigfull manner.
Regards, Dana.
They do not switch simultaneously, look at datasheets for timing info.why ? if they open and close simultaneously ,from source to drain and other from emitter to collector
20n60c3Hello,
What is the full number of the parts?
the 20N60 van be a mosfet and a IGBT, depending on the number:
Bertus
