Paidashu display and pcb for 27000mah power bank
arnieboy66
Joined Nov 10, 2024
5
Hi - I have a Paidashu 27000mah power bank which was damaged by a faulty usb cable. When I search for a new pcb I only find 18650 charging boards. Are these still compatible, even if the wrong size? I can't find an exact match for mine anywhere. Thanks in advance.
KeithWalker
Joined Jul 10, 2017
3,625
I think you are going to have problems matching the spec if you really believe that small power bank contains a 27 Ampere-Hour Li-Ion cell ! It's much more likely to be 2,700mAH.
arnieboy66
Joined Nov 10, 2024
5
Hi
It does appear to be 27000, I attach a photo with the batteries which are huge and on my other identical one charges several phones completely, by far and away the biggest capacity of any power bank I have.
KeithWalker
Joined Jul 10, 2017
3,625
If it really was 27,000mAH capacity, it would recharge about nine cellphones from one charge. Comparing the size of the two cells to the USB connectors, I would guess that the real maximum total capacity is around 8,000mAH.
