Oshonsoft programs with INTERRUPTS and PARSE
jjw
Joined Dec 24, 2013
823
If you have an oscilloscope then use it. It gives better information than an LED at high frequencies.
Write a main loop to toggle an LED without using delay.
Show your code and report back.
The program in #54 is for the simulator.
camerart
Joined Feb 25, 2013
3,853
Hi Mr C,
I have an oscilloscope, but I also have a simulator, shown here, which is good for this sort of thing.
Here it shows the Program and result:
C
jjw
Joined Dec 24, 2013
823
This is a barebones Oshonsoft simulator demo to receive a message by interrupts.
No checking of errors, overflows, message start characters etc.
You have to do the hard work.
Code:
'**** Oshonsoft Basic Simulation for USART Rx with interrupts
'PIC8LF4620 8MHz
Define SIMULATION_WAITMS_VALUE = 1
Define CLOCK_FREQUENCY = 8
'*** Setup interrupts ***
RCON.IPEN = 1  'IPEN: Int Priority Enable bit 'This MUST be included when using Interrupts (Priority HIGH/LOW)[#189 hserin blocking]
PIE1 = %00100000  'RCIE: EUSART Receive Interrupt Enable bit [ 1=en ]
INTCON.PEIE = 1  'PEIE/GIEL: Peripheral Interrupt Enable bit
INTCON.GIE = 1  'GIE/GIEH: Global Interrupt Enable bit *** s
' **** Setup Hw USART ****
Hseropen 9600
Dim char As Byte
Dim str1(20) As Byte ' *** received message comes to str1
Dim rxi As Byte    ïndex to Str1
Dim msg_rdy As Bit
rxi = 0
msg_rdy = 0
Enable High
Main:
Break  '***stop and put a short msg ending with "!" in to Simulator Rx window
While not msg_rdy // **** the real program can run here and check msg_rdy as needed
Wend
Break  '**** stop, now the Str1 can be looked at the variable window
End
On High Interrupt
Save System
If PIR1.RCIF = 1 Then
  char = RCREG
  str1(rxi) = char
  rxi = rxi + 1
Endif
If char = "!" Then  ' ***  ends the message ****
  msg_rdy = 1
Endif
Resume
camerart
Joined Feb 25, 2013
3,853
Code:
'PIC8LF4620 8MHz
Hseropen 9600
Dim char As Byte
Dim msg_rdy As Bit
rxi = 0
msg_rdy = 0
Enable High
Main:
Wend
End
On High Interrupt
Save System
  char = RCREG
  str1(rxi) = char
  rxi = rxi + 1
Endif
  msg_rdy = 1
Endif
Resume
Hi J,
And I was looking forward to doing this myself ;)
Thanks very much, I'll put the Aspirin away, much appreciated.
Regarding the 8BIT 16 BIT choice: [ RCSTA.RX9 = 0 '0 = Selects 8-bit reception ] and This routine uses 8BIT, but later there are H and L BYTES, should this be set for 8 or 16BIT?
Regarding the BAUD rate: How do I select [ BAUDCON.BRG16 = 1 '1 = 16-bit Baud Rate Generator – SPBRGH and SPBRG ] ?
Thanks, C.
jjw
Joined Dec 24, 2013
823
Hi J,
Thanks, C.
I think Hseropen 9600 takes care of it. It is command for HW Usart
jjw
Joined Dec 24, 2013
823
Hi E,
My question was more to do with setting up UART or PIC.
The UART uses 8BIT, but the MAIN LOOP uses Two's compliment H and L.
As I'm setting up the UART, I assme that I should set that setting to 8BIT, but for the SPI H an L BYTEs they will need 16BIT.
Thanks, C.
Can't you just send 16bit as two 8bit bytes, when you know where they are in the message?
camerart
Joined Feb 25, 2013
3,853
Hi J,
I just checked on one of the peripheral D/S and it appears that one SENDs 3x BYTEs. I'll leave this till later, and leave the UART [ RCSTA.RX9 ] set to 8BIT, for now. thanks.
C.
camerart
Joined Feb 25, 2013
3,853
hi,
'While msg_rdy = 0 'the real program can run here and check msg_rdy as needed
When is msg_rdy NOT = 0. ?
E
Hi E,
This is a temporary LOOP, that is broken by the INTERRUPT, and will not be there once the MAIN program comes back.
I haven't checked the actual timing, but just watching the SIM, I'm surprised by the time the processor has to go back to the MAIN LOOP in between $ Sentence digits, coming in.
If you're testing with the SIM, here are some sentences:
$GPRMC,123519,A,4807.038,N,01131.000,W,022.4,084.4,230394,003.1,W*6A?
$GPRMC,123519,A,4807.038,N,01131.000,W,W*6A? ['C' = HEX 0X43 DEC 67]
$QEIDEG,123,W [ 'D' = HEX 0X47 DEC 71]
$REMOTE,12,20,50,W [remvolt,remalt,remdist],? [ 'R' = HEX 0X52 DEC 82]
C
jjw
Joined Dec 24, 2013
823
Hi E,
$GPRMC,123519,A,4807.038,N,01131.000,W,W*6A? 'C' = HEX 0X43 DEC 67
$QEIDEG,123,W 'D' = HEX 0X47 DEC 71
$REMOTE,12,20,50,W [remvolt,remalt,remdist],? 'R' = HEX 0X52 DEC 82
C
In the ISR when at the end of the message set msg_rdy = 1
jjw
Joined Dec 24, 2013
823
Hi E,
C
The simulator is really slow when receiving characters.
A message ~5 charactes took tens of seconds in the original demo.
Real time execution of the ISR is about 40us at 8MHz.
camerart
Joined Feb 25, 2013
3,853
Hi J,
I know, from the hours, I've sat watching it :)
I'm not used to these speeds, so take some comprehending, but my thought was that there appears to be some time in between the $Sentence digits, for the processor to work on the MAIN LOOP, until the next digit.
C
ericgibbs
Joined Jan 29, 2010
21,642
hi C,
This is a simple working bit of code, you should be able to add to it.
Every incoming RX char generates an Interrupt.
Run it,
Type in
$1234? or any other String starting with $ and ending with ? [ ==crlf], it should display the full string.
then type in a test string without the starting $, it should print Error.
Do you follow OK.?
E
jjw
Joined Dec 24, 2013
823
Hi J,
C
The ISR slows the processor less than 4% at 8MHz. How critical it is to detect fast the end of the message ?
