Oshonsoft 18F4431 8mHx XTL XPLL = 32mHz with PIN out.
camerart
Joined Feb 25, 2013
3,853
I'm using an 18F4431 PIC in Oshonsoft, with an 8mHz XTL and the CONFIG setting PLL, so 32mHz.
Here is the config:
Is it possible to have a these settings but with a CLK out PIN?
C
geekoftheweek
Joined Oct 6, 2013
1,429
What's EC MODE?
EC = External Oscillator. You connect the clock to RA7 and the clock out is on RA6 whereas HS mode uses both RA7 and RA6 to connect to a crystal.
Internal oscillator will work also with clock out.
Either way you won't get 32MHz out. It will always be the oscillator frequency / 4 as stated in the datasheet.
camerart
Joined Feb 25, 2013
3,853
Hi E and G,
Ok, thanks.
C
camerart
Joined Feb 25, 2013
3,853
Wrong clock! I was trying to get an actual Osc to output to a pin, but it was inside the program, I was editing. It is a CCPR1 match output CLK pin.
More time wasting sorry.
C
