how do you do an analysis on this circuit to get the gain = 0?
this is like a voltage follower but with a resistor at the input terminal.
i know the input resistance is 160k ohm and output resistance is 0 ohm.
About this circuit. i tried to redraw the circuit as such,
cos there is a common ground between the input voltage, 20k resistor and Vo
----10k---100k---|--------100k-----|
|xxxxxxxxxxxxxxxx| xxxxxxxxxxxxxxxxx|
|xxxxxxxxxxxxxx | xxxxxxxxxxxxxxxxx|
Vi xxxxxxxxxxxxxx 20k xxxxxxxxxxxxxxx Vo
| xxxxxxxxxxxxxxx|xxxxxxxxxxxxxxxxx |
I did using superposition.
going around left side and right side.
Vi ( (20k//100k)/(110k + 20k//100k) ) = Vo (- (110k//20k)/(110k//20k + 100k))
but it doesn't give me the correct answer which is -70 gain
