Opening laptop battery and charger
peterlars
Joined Feb 20, 2017
7
Hi guys,
I wanted to open a laptop battery and a laptop charger without damaging the case. I was thinking of applying heat. Does anyone know up to what temperature is safe to go? What temperature li-ion batteries and electrolytic capacitors can reach? Alternatively can you suggest another way of opening them?
Thank you.
Irving
Joined Jan 30, 2016
5,170
Often the only way is to use a dremel circular cutter carefully along the seam, going in a few hundreths of a mm at a time to separate the 2 halves of the case without damaging whats inside.
