I keep telling you to look on the internet:how is it 2R2? Confused now, as the solution that was provided for the problem I mentioned in previous post, we used the Ad I posted. With Acm=0, so would Acm=0 here?
http://www.allaboutcircuits.com/vol_3/chpt_8/10.html
http://en.wikipedia.org/wiki/Instrumentation_amplifier
http://www.intersil.com/data/an/an1298.pdf
Common mode gain is a function of R3 and R4. If both R3's are truly equal, and both R4's are truly equal, and the op amps are ideal (infinite CMRR), then the common mode gain will be zero.
