Op-amp input resistance and output resistance
studyhard24
Joined Jun 20, 2022
35
My approach: (updated the gain value)
As the question said the Op-amp is Ideal so I thought this could be the approach. But there are 5 marks for this question, so there must be something more to do here.
Let me know where I've mistaken, thank you for your precious time.
studyhard24
Joined Jun 20, 2022
35
t
hi 24,
10^6 / 10^3 = ????
E
the other 0 is a bit far, Sorry for the inconvenience, Sir. The voltage gain calculation is easy. And as Mr Bob said the input resistance will be considered the 1K Ohm. I've understood that now, But what about the output resistance?? will it be the reference voltage i.e. 1 M ohms?
dl324
Joined Mar 30, 2015
18,453
It's unfortunate that you were able to read his post before it could be removed. That isn't the way homework help is supposed to work. We're supposed to give hints to make you remember what you were taught. Giving you answers won't help you on tests and most schools would consider getting answers from others to be cheating.
studyhard24
Joined Jun 20, 2022
35
Sir, I have calculated the input impedance.
38,723
Don't guess.
Think about it.
The output sees the 1Mohm feedback resistor in parallel with the op amp output.
So logically, what do you think would determine the output impedance?
studyhard24
Joined Jun 20, 2022
35
Sir, the 1 M Ohm and Op-amp are parallel to each other.
But there is no data sheet that was supposed to contain Zout, Aol.
Like for this example:
LvW
Joined Jun 13, 2013
2,035
Your formula for Zout contains the feedback effect (reduction factor due to loop gain) - and this is totally correct.
As a result, the output impedance is so small that in most cases it can be neglected - even without knowing some values for Aol and Rout (for the opamp alone)
LvW
Joined Jun 13, 2013
2,035
I get it now, the Output resistance of the circuit equals the output resistance of the OP-AMP i.e., zero ohms.
No - consult your own result in post#11.
The output resistance of the opamp normally is app. (20...100) Ohms.
However, due to negative feedback the output resistance of the whole circuit is less by a factor (1+loop gain).
THAT is the reason you very often can neglect this value (because it is very small but never zero).
ericgibbs
Joined Jan 29, 2010
21,547
hi @studyhard24
In the original question the OPA is stated as Ideal, so your answer to this question, saying the output resistance is Zero ohms, is correct.:)
E
LvW
Joined Jun 13, 2013
2,035
hi @studyhard24
E
Yes, thats correct as far as the original question (idealized opamp model) is concerned.
However, for my understanding we are in this discussion already one step further (see the contribution of studyhard24 in post '11). That is the background for my contribution in post'16 (real opamp).
