With the inverting amplifier configuration, the sensor's internal resistance and the input resistor of the amplifier are in series and form a voltage divider which reduces the effective output voltage of the sensor. With the non-inverting configuration there is no voltage reduction because the amplifier's input impedance is extremely high, if not infinite.I wanted to know the reason, why loading effect comes into picture if restive sensor is connected with inverting op-amp while no loading effect with non inverting op-amp?
