I was wondering if you guys can help. I was building a weghing scale using some strain gauges and an A-D going into a Pi. I hvae used a 741 op amp with the offset nulling pot. Without having to use 2 batteries to create a negative polarity to feed into the offet nulling part of the cct. can this be done by using just 1 battery and using the ground begating the need for -ve power source ?
Thanks for your help in advance
