- Joined Jan 23, 2018
- 27,530
This statement does not make sense. If you need to control multiple drives and there is not enough current available then use multiple op-amps, one per drive, connected as unity gain voltage followers.I need to boost an analoug 0 to 10vdc input. When I try to use this signal to speed control VFD,S it can only handle 2 before voltage drop due to the resistance the VFD input, so I if use the incoming 0 to 10vdc to a dual op amp it can drive more tandem VFD,S especially if it had a high current output.
