One USB to 3 UART
vikas kumar_1516955635
Joined Jan 26, 2018
Please see the attached image.
I have three devices with only UART in all three devices
I need to communicate with all three devices at the same time using one USB
I have see USB to UART using FTDI converter . But that is for one to one.
Here one USB to 3 UART I need to connect. Is it possible ?
I saw one FTDI device FT4232H and the datasheet says "Single chip USB to four channels UART (RS232, RS422 or RS485) or Bit-Bang interfaces. "
can I use this device for my application ?
If yes, then how do I interface AD,BD,CD,DD Bus0 to Bus 7 to my device which has got only tx rx, Do I need any interface IC?
Also I know RS232 is multi drop. Can I use RS232 for this sort of communication ?
geekoftheweek
Joined Oct 6, 2013
1,429
Check out this datasheet also... https://www.ftdichip.com/Support/Documents/DataSheets/ICs/DS_FT4232H.pdf Starting on the bottom of page 13 it shows the different pins functions. Judging from your post I think you have https://www.ftdichip.com/Support/Documents/DataSheets/Modules/DS_FT4232H_Mini_Module.pdf already. Match up the tables between the two.
I'm assuming in the "normal" mode the driver would just create four virtual ports like a normal serial port to use to connect with in program.
