One meter of wire loose vs. one meter coiled up
Hamlet
Joined Jun 10, 2015
560
So that thing called inductance...
Does a coil of wire 1-meter length have more inductance than a straight wire of the same length?
Does coiling a wire change anything, or is it just something we do
to make it more compact and easier to work with? (I know there's something about inter-winding capacitance, but let's leave that alone for now.)
The wire wound in coil shape will have higher inductance since it creates a better magnetic circuit or magnetic path, i.e. more closed. On other hand the straight wire creates a magnetic path more open.
BobTPH
Joined Jun 5, 2013
11,665
Self inductance is an effect of the magnetic field produced by the wire on itself. Coiling it concentrates the field, so, yes, the inductance is higher even for a single turn.
When there is more than one turn, each turn affects not only itself, but the other turns as well. That is why the inductance of a coil is proportional to the square of the number of turns.
Jon Chandler
Joined Jun 12, 2008
1,652
Loop area is a concern for picking up interference. The loop area, the area between conductors, is very small for a twisted pair – low electromagnetic pickup. Between two loose conductors to a sensor, it's much larger – more potential for noise pickup.
