Once upon a time there was a flasher IC...
Externet
Joined Nov 29, 2005
2,674
Greetings
The LM3909 was an adjustable rate flasher; now it is a ripoff.
Is there a modern chip or an useable portion of a chip guts that does the same, 30+ years later ?
Adjustable duty, 1.5V ? There is several clever circuits published on the web to perform similar. Any that you prefer ? No 555s, please.
dl324
Joined Mar 30, 2015
18,454
I think a joule thief is your best bet.
Didn't realize LM3909 had gotten so expensive. I got half a dozen free NTE parts at a swap meet 4-5 months ago. Plus, I have stock from the 70's...
SamR
Joined Mar 19, 2019
5,535
Even the cheapest ones on AliX... And not much better priced in small lots. Note the only 92% Positive Feedback for the vendor.
dl324
Joined Mar 30, 2015
18,454
I'd only buy commodity semiconductors on Ali Express. They're less likely to be counterfeit.
This photo gives enough detail to tell it's counterfeit:
Note the debris in the pin 1 mark and the pitting (non-shiny) nature of the pins.
SamR
Joined Mar 19, 2019
5,535
Yes, I would avoid them also for this. Just for comparison and the price has been relatively high for years which is why my blinkies either used a uP or 555. One possibility that Mr. Chips didn't mention is using an ATTiny chip and programming it to blink. The Arduino IDE even comes with a standard 1s blink example program. The ATTiny85 is significantly cheaper then the LM3909 albeit more than the 555.
djsfantasi
Joined Apr 11, 2010
9,237
However, you do have to buy an ATTiny programmer. It’s $15-$20 on Sparkfun. But it’s a one time purchase and can be amortized over many projects.
In case it’s not obvious, you can use the Arduino IDE to program and upload code to the ATTiny.
AnalogKid
Joined Aug 1, 2013
12,264
In the world of IC oscillator designs, the 3909 was unique. The reason it got such a relatively long battery life is that it used the charge built up in the capacitor (as part of the timing circuit) to power the LED. I always like this getting double duty out of those electrons, and have "borrowed{" the idea a few times.
ak
Externet
Joined Nov 29, 2005
2,674
With all the brains of this site together; is there a way to re-purpose a YX8018 chip (used in 1.25V solar garden lights) to make it flash ?
-The solar panel could be ignored-
38,764
Below is the LTspice simulation of a two transistor circuit, similar to Mr Chips' circuit, that adds the capacitor discharge voltage to the battery voltage to drive LED from a 1.5V battery (similar to the LM3909).
It oscillates at a 1s period with about a 6ms pulse to 1/2 amplitude with about a 60mA peak amplitude.
The average current draw from the battery is about 1mA.
The simulation works down to a 1V battery voltage.
