Technical Details Summary:
Product: Samsung UN46D6420UF 46" LCD TV
Board Model ID: SH120PMB4SV0 (Samsung?) (T Con Board)
Board Main Microprocessor ID: AMLCD LP410A1 (...)
Board DC-DC IC: RT9979GQW
Background:
Goal: I hope I can get a positive helpful answer here.
Description: So, I tried to search online for a corresponding datasheet and/or schematics for the microprocessor, DC-DC IC, and the board to no avail. Found one video on YT describing a schematic for the DC-DC PM IC, but it was non-English (Hindi). I did find this one image floating around online on various websites of what appears to be a makeshift technician's servicing "schematic". It was essentially a picture of the board that was marked up with voltages and lines pointing toward the corresponding SMD component. Please see image below:
The image:
I am guessing it was made by resourceful and practical technicians from another country (say from Pakistan or India). From my guestimation, it looks like those are the expected measurements to see if the board is working fine.
Questions:
So, on to the questions:
Question 1: What do those voltage mark ups mean? (Is my aforementioned guestimation correct? Is this common practice with professional technicians in the West?)
Question 2: If I were to desolder the board to replace the SMDs (capacitors and resistors), could I measure them (capacitor tester + multimeter), and replace with an matching SMD component?
Question 3: Any suggestions on a good place to get a set of SMD components for a hobbyist (I'm not a pro!)
Thank you!
Background:
The image:
Questions:
Thank you!
