I just thought about demorgans computer again! I get rid of EVERYTHING, and I just have not to make all my gates, and i can actually make an or out of nots, and then make everything out of or, with nots after.
I make or out of not, by doing a variable not ( a xor), and then inverting the polarity, and not inverting, because its mutually exclusive only one or the other comes up, and then recombining the pathways to the same polarity. (turns to or) theres 5 nots to do it!
You have to switch polarities every time you not.
It runs on AC, and I mean polarity by 180* or 0*, I use AC, because im going through iron cores to separate my nots from each other (gotta keep em separated.). and the whole thing is just one unit repeating!
Its completely insensitive to the volatile ac, and I make sure not to double magnetic inductance, by making the or from nots especially.
I drew up a ram bit, its not here because its errored, and it was before I worked out this or from 5 nots idea but it should be about 50 - 60 or so of them (~4x4x4 in a volume) (nots) in the register counting all the ands you have to make out of the nots, so its kinda not the most efficient thing, but I think if it works, ill love to stick to this thing!
