Ohm's law and power equation
rakker579
Joined Jul 5, 2021
Hello I have a question about electricity. I know that transmitting power over long distance is better in AC. I also heard that the voltage needs to be high to reduce losses. I wanted to calculate this for myself.
Imagine there is a windmill that produces 100 KW of power. This 100 KW needs to be transported over a 1 km wire that has 1 ohm of resistance. We can transfer this 100kW of power at 1kV or 10kV. But we are going to look which one is most beneficial.
When we send the 100kW at 1kV:
- This means we have 100A (Power/Voltage) with a loss of 10kW (Current^2*Resistance).
When we send the 100kW at 10 kV:
- This means we have 10A (Power/voltage) with a loss of 0.1kW (Current^2*Resistance).
This proves that the losses are less when the voltage is high than when the voltage is low. However I noticed something odd. When we send the 100kW at 1 kV I calculated that the current is 100A via the power equation (100 000 / 1 000). But when I calculate the current via ohm's law I get 1kA (1 000 * 1). What am I doing wrong?
rakker579
Joined Jul 5, 2021
EDIT: found it, can't use ohms law because not the whole 1kV is used on the transmission wire
35,279
Ohm’s Law still works.
You are using the wrong value for the load resistance.
The resistance of the load is not 1Ω.
