offset voltage calculation (c)
38,747
You need to include the temperature effect on the offset but your value looks correct at room temperature for that circuit.
Viktor Vaughn
Joined Mar 21, 2015
24
Ok, so when I add the temperature coefficient it would be 20mv + 10uv(50) = 20.5mv. I can't fathom where he is getting 12.8mv from , unless his calculations are wrong.
kdillinger
Joined Jul 26, 2009
141
You should double check with your professor regarding the 12.8mV answer. The question as posed is missing information. Offset voltage coefficient (also known as offset voltage drift) is a calculation based off measurements during test. Using drift in a total offset measurement requires a change in temperature to understand its effect. The question simply states 50C.
Viktor Vaughn
Joined Mar 21, 2015
24
Your correct! Im going to ask him about his 12.8mv calculation, because by the text in the book, I cant see any other possibility other than 20.5mv
