Obtaining value for amplifier - datasheet
njk
Joined Aug 22, 2017
I have a sensor and attached is 1 page of a datasheet and the functional diagram.
My sensor outputs amplified voltages, and I would ideally like to have raw voltage. On the functional diagram, the raw values are coming off the Thermopile array (left side) and then go through MUK to the amp. I need to know this amp value to get my raw voltage value. No luck contacting manufacturer so is there some type of standard that is used for this type of amplifier?
any way to find out what it is?
Thanks,
Natalie
wayneh
Joined Sep 9, 2010
18,104
Can you physically hack the sensor, to get at the voltages you want? Lacking that, I cannot imagine the manufacturer sharing it with you.
njk
Joined Aug 22, 2017
I have spares so I can do whatever it takes to get the value of the amplifier. I really need to know how much it amplifies the raw voltage value that the sensor outputs.
What do I need to do?
Natalie
