Obtaining High Drain 18650 Li-ion Cells
MrAl
Joined Jun 17, 2014
13,738
Hello there,
I need a couple high drain 18650 cells that are capable of say 20 amps but might consider 10amps. In fact, maybe i better stick to the 20 amp rating.
That is the MAX DISCHARGE current rating.
They also MUST have a button top, NOT a flat top.
I've looked around and cant seem to find any, or at least for a price under 33 dollars USD for 2 cells.
Any ideas or links would be helpful, thanks.
NOTE that they must be button top, not flat top, and they must have a current max discharge rating of 10 amps but 20 amps or more preferred.
That's listed:
1. Button Top.
2. "Max discharge" rating of 10 amps, but 20 amps or more preferred.
Reason for the tight specs:
IT's a high power flashlight and the way the battery compartment is set up it wont work with flat top batteries, and there are so many high power LEDs in it that it has to have high drain batteries. Even 10 amps might not be enough even with four batteries installed, that's why i was shooting for 20 amps or more like 30 amps. The ones i use now are modified flat tops, but i dont want to have to modify any more of them it's a big pain.
