Not attaining the desire current (Adjustable current source)
VictorMBS
Joined Jun 13, 2021
6
Hello Guys. At the schematic below, you can see a circuit that I picked from a datasheet. In this circuit, I should expect a maximum current of 4 A flowing at the fake resistor of 0.0001 ohms. Unfortunately, after I brought the circuit to the real world, I attained a maximum current of 2.40 A. What could be the cause of this problem? I used two integrated circuits, a LM338 TO-220 and a LM317T.
Ian0
Joined Aug 7, 2020
9,835
You should get the maximum current with the preset's wiper at the top on your drawing. In which case everything other than V2, U1, R1 and R3 are irrelevant. What is the voltage on the LM338 ADJ terminal?
VictorMBS
Joined Jun 13, 2021
6
Hi Ian0! Thank you for your comment! The voltage between adjust and input terminal of LM338 was 4.95 V. Besides that, the voltage between adjust pin and output pin was 0.75 V.
Ian0
Joined Aug 7, 2020
9,835
It would appear to put a constant current through the preset, so that a voltage could be added to the voltage drop across the current sense resistor, creating a constant current output that could be varied down to zero.
I can think of better ways . . . .
but presumably some new graduate engineer was told to design a variable constant current source circuit that could be put in the LM338 datasheet.
But if there's only 0.75V between output and adj then something is wrong with the LM338. It would appear to have enough headroom, unless the load resistor isn't a low as it is claimed.
VictorMBS
Joined Jun 13, 2021
6
What is the purpose of that rather strange looking circuit?
What "datasheet" did that come from?
Hello! The purpose of this circuit was regulate the current that flows between the path where is R3. We should expect a maximum current of 4 A and a minimum current of 0 A. We attained the desires values between 0 to 2.4 A, but, unfortunately, we didn’t get values above 2.4 A. The purpose of the potentiometer it is regulate the current that flows through the path where is R3. I picked the circuit from LM338 texas instruments datasheet. I just make a few changes because I didn’t have the resistors that appeared in the datasheet.7C49EF93-E83D-49E6-AB46-094217094EF2.png
Tonyr1084
Joined Sep 24, 2015
7,904
Again, R4 is acting like a voltage divider and is probably what is causing your issue. As Ian0 said before, there's a lot of unnecessary hardware in that circuit. Lose R4 and everything below that and I predict success.
I would add (what you're calling U3) as being necessary.
VictorMBS
Joined Jun 13, 2021
6
My guess is R4 creating a voltage divider, which is why you're seeing so low a voltage.
Hi Tony! In some of my tests, I didn’t put the R4 resistor and I obtained the same 2.4 A maximum current. Here is the another circuit schematic. Besides that, I can not remove everything below because I need of these components to control the current that is going to R3. If I remove all of the componentes below R4 I wouldn't be able to change the current flowing through R3.1633705451043.png
Ian0
Joined Aug 7, 2020
9,835
Reduce the value of R2 to 120 as mentioned in the TI schematic in post #8 as R3.
You must also replace the preset for a 150Ω preset. Has anyone ever seen a 150Ω preset?
I suggest that for initial testing, just move the preset to its minimum setting (so it shorts ADJ to R1) because that would give the maximum output. Then, if that works, check whether the adjustment works.
sagor
Joined Mar 10, 2019
912
Accordin g to datasheet, you get the 5A rating only if Vin-Vout <10V. If Vin-Vout is 30V, maximum current is 1A due to current limiting. So, your 2.4A may be current limiting due to the input voltage vs the output voltage being more than 10V. I think the simulation shows 5V, which may be ok. That said, heat generated inside the LM338 may still limit the current.
The TO-3 can design is rated 50W dissipation for the datasheet specifications, the TO-220 is rated 25W dissipation for the same specifications on the datasheet (TI datasheets).
