Not able to see cut out on PCB design Gerber files
Md_Yusuf
Joined Aug 2, 2022
23
Hi, everybody I have designed a PCB in which I have given the the cut out on PCB but this cut out I am not able to see on my Gerber files why is this ok or is it problem on my PCB out thank you
I have attached the PCB design board 2D and 3D view
joeyd999
Joined Jun 6, 2011
6,478
Add some punctuation to your question, and perhaps include your Gerber files.
panic mode
Joined Oct 10, 2011
5,417
those cutouts would normally be on the same layer as edge cuts. the screenshots show them rendered correctly. if the gerbers contain outer edges but not cutouts, check what layer they are on.
