normal NAND gate and Schmitt trigger NAND
vinodquilon
Joined Dec 24, 2009
234
What is the difference between normal NAND gate and Schmitt trigger NAND ?
Does it is interchangeable in an application ?
Wendy
Joined Mar 24, 2008
23,869
Yes. Visualize a convention NAND gate with a simple non inverting Schmitt trigger in front of each input.
SgtWookie
Joined Jul 17, 2007
22,230
Well, you can use a Schmitt-trigger NAND to replace a regular NAND in most cases; if the inputs have fast rise/fall times.
However, trying to use a regular NAND for a Schmitt-trigger NAND may cause problems, particularly if the input(s) to the gate have slow rise or fall times.
