noisy amplifier
Rubs
Joined Jun 20, 2011
16
can anyone help me design a "noisy" feedback amplifier with amplifier gain of 100 and signal to noise ratio of 60dB
Audioguru
Joined Dec 20, 2007
11,248
Most people simply use a low noise audio opamp when they need low noise, not a noisy 43 years old 741 opamp.
Audio opamps have a signal to noise ratio of up to 120dB.
t06afre
Joined May 11, 2009
5,934
Use long cables not sheiled for the signal and power supply leads. And do not twist them them together. Use an unregulated power supply.
Georacer
Joined Nov 25, 2009
5,182
If you can get your hands in one, you can also use a 301 OpAmp. It doesn't have internal compensation and is particularly noisy.
Rubs
Joined Jun 20, 2011
16
i simulated this circuit in LTSPICE but the results arent right...could anyone tell me whats wrong with this design and suggest a possible solution
Wendy
Joined Mar 24, 2008
23,863
Another though, you could deliberately introduce noise into the front end of the schematic. Bias up a zener diode with 10ma and have it feed in somewhere, for example. It is an old trick used to generate white noise.
Audioguru
Joined Dec 20, 2007
11,248
The polarity of V2 is backwards because it is supposed to be a negative supply. You have its negative terminal connected to ground so it is actually a positive supply.
Why do you take the input signal and attenuate it down to almost nothing, then amplify it a lot?
your negative feedback around both opaps looks odd and might cause oscillation.
Rubs
Joined Jun 20, 2011
16
the frequency response doesnot give a gain of 40dB and the transient analysis gives out an output voltage of 700uV :-/ so clearly the design is not right...plz tell me what changes should i make
Rubs
Joined Jun 20, 2011
16
i have given V2 a value of -15V i dnt think it would make much of a difference... and plz could you tell me explicitly wat changes i should make
Audioguru
Joined Dec 20, 2007
11,248
I don't know why:
1) You have an attenuator at the input of the first opamp.
2) You have two opamps when the second opamp by itself will work.
3) You feed the output of the second opamp back to the input of the first opamp as some kind of feedback.
CDRIVE
Joined Jul 1, 2008
2,219
Yes, great idea. Something similar to this was/is used by hams to make a noise bridge used for measuring 50Ω Z.
