2nd image looks fine to me..dunnoInstead of V1 in the second photo, I solved it by typing V2.
don't understand the question : please explain (cos used supernode to arrive at answer)Why can't the super node rule apply?
Okay...Maybe you are correct butQuestion:Find the node voltages and find the power of the 6(i phi) source.Yes the third equation is the same as the first equation I have already written 2 equations 1 and 2. Isn't the first node 60 V? I think the current there does not matter.When there is a voltage source between two nodes, the super node rule needs to be applied but I'm trying to understand why the first equation in my first photo isn't,maybe correct or notThank you for help me.
destroy the current?You are right.Yes there needs to be a current., I think I need to include the current there but if I add the current there, how can I destroy it? So how do I solve the question?
| Thread starter | Similar threads | Forum | Replies | Date |
| P | Node Voltage Analysis Problem | Homework Help | 36 | |
| T | Node Analysis of 2nd order Sallen-Key question | General Science, Physics & Math | 8 | |
| C | Node Analysis Question(Hard for me) | Homework Help | 7 | |
| E | Help me to slove Nodel Analysis & node admittance matrix question | Homework Help | 0 | |
Node analysis question. | Homework Help | 1 |
