geekoftheweek
- Joined Oct 6, 2013
- 1,429
Correct. Disconnect the harness from the sensor and jump 1 and 3.Let me go try that.
u mean, place a jumper wire between pins 1 and 3?
Also thought while out mowing the grass that since your sensors have three wires and one of them is power and one is ground you should be getting some sort of signal out when the engine is cranked as long as they are getting power and ground. There is some sort of processing going on inside the sensor to maybe clean up signals and such... there just should be a measurable change.
