Nippon Denso 052100-0940 Wiper Control Relay
wdts
Joined May 16, 2022
There are 4 pins in this Relay.
Could someone kindly inform me which goes where ? Thank you in advance
wdts
Joined May 16, 2022
Thank you for the early response.
Toyota part number on the relay is 85940-89103. I will upload a Photo
Regards
wdts
Joined May 16, 2022
What model Toyota is it off?
I am on a modification job.
It is for a Toyota CE96 Diesel Wagon (1990) which originally comes without intermittent wipers and having a 4 pin connections at the Wiper Motor.
This control relay I have sourced from a used parts shop & similar to ones in many Toyota models during 1980/1990s
Thank you
debe
Joined Sep 21, 2010
1,419
I agree you probably need to look inside as some are not relays, but have a circuit board & components inside.
