NiCd battery charger circuit help
Hamza Žunić
Joined Jun 17, 2017
11
Hello everyone,
I found this simple circuit on the internet, but I need help with it. I am not very good with designing circuits.
I was wondering if someone would help me make the most simple circuit, within the circuit I provided, that turns off charging automatically when the battery reaches full charge. I want to charge a single NiCd 1400 mAh battery with this circuit.
Here is the original post: https://www.eeweb.com/extreme-circuits/low-cost-universal-battery-charger-schematic
Thank you in advance. Best regards.
dl324
Joined Mar 30, 2015
18,477
That simple circuit won't charge NiCd batteries properly.
http://batteryuniversity.com/learn/article/charging_nickel_based_batteries
Excerpt from article referenced above:
To achieve a reliable voltage signature, the charge rate must be 0.5C and higher. Slower charging produces a less defined voltage drop, especially if the cells are mismatched in which case each cell reaches full charge at a different time point. To assure reliable full-charge detection, most NDV chargers also use a voltage plateau detector that terminates the charge when the voltage remains in a steady state for a given time. These chargers also include delta temperature, absolute temperature and a time-out timer.
AlbertHall
Joined Jun 4, 2014
12,653
That circuit is intended to be used at a charge rate of C/10 (15 hour rate). NiCd batteries can tolerate overcharge at that rate and that circuit will satisfactorily charge NiCd batteries as long as the C/10 current is used.
For faster charging that circuit is not suitable and the NDV method should be used.
Hamza Žunić
Joined Jun 17, 2017
11
So I can charge a single cell with this circuit with 140mA and won't damage it? The author says that I can double the current and will not damage the battery?
Hamza Žunić
Joined Jun 17, 2017
11
AlbertHall
Joined Jun 4, 2014
12,653
You can charge at 140mA if the cell capacity is 1.4Ah and then the charge time is not critical. If you double the current then you should discharge the cell before charging it and it is important to remove the charging circuit after 7.5 hours. Leaving it too long will damage the cell.
Hamza Žunić
Joined Jun 17, 2017
11
Ok, that is clearer to me. But that is the question, can somebody help me build a simple circuit that will auto turn off charging when the battery is full-charged?
AlbertHall
Joined Jun 4, 2014
12,653
If you use the 15 hour rate you don't need to worry about auto-turn off and is the simplest way to do it. It is only if you need to charge fast that you need to worry about overcharging.
Is the 15 hour rate too slow for you?
Hamza Žunić
Joined Jun 17, 2017
11
Yes it is, the perfect charging time for me would be 7-9 (overnight) hours without a need of turning it off by myself. I saw some circuits with the LM317 that can auto turn off the charging?
dl324
Joined Mar 30, 2015
18,477
I intend to use 2 cells for let's say a power bank. That is not very demanding circuit. Can I use this charger circuit for charging NiCd batteries, and then use them in power bank. Will I be able to use is a year or so without damaging the batteries?
I wouldn't use the circuit referenced, and I definitely wouldn't charge two batteries in series. Invariably, one of the cells will be weaker than the other. The weak cell will charge first and will spend more time in overcharge (i.e. it wiill be cooked and it's deterioration will accelerate).
Read the article I referenced.
Hamza Žunić
Joined Jun 17, 2017
11
I read it, and sorry for not mentioning but I plan to charge individual cells, not connected in series.
