Newbie LED problem
1out1der
Joined Sep 15, 2013
9
Thanks guys, this has been a great help. Wayne, I'm obviously not doing real science nor do I care too much about total accuracy, the effect I'm interested in- very power efficient photosynthesis- would be so pronounced that it would leave a huge margin for error. So that blog entry has been most informative.
mcgyvr, I will certainly look into Arduino would you recommend a particular beginners resource?
THE_RB
Joined Feb 11, 2008
5,438
Here is a very simple way to do it with a PIC micro;
Rich (BB code):
  // C code to make exactly 5kHz, exactly 1% duty (PIC xtal = 4MHz)
  PR2 = (200-1);     // set TMR2 period to 200 uS
  while(1)           // loop and make the freq
    if(PIR1.TMR2IF)       // if TMR2 rolled
      PIR1.TMR2IF = 0;    // clear roll flag
      PORTB = 0x01;       // RB0 is output pin, now HI
      PORTB = 0x00;       // RB0 now LO again (was HI for 2uS)
You need to add a couple of lines of code to suit any PIC you choose, to setup port pins direction and enable TMR2.
Bernard
Joined Aug 7, 2008
5,784
Surprise-surprise- I did not think the LED would be visable, mine is yellow 1 W & about as bright as a 20 mA LED; @ 400 mA, 2μs on, 198μs off. Using 555 with 6 V battery, 10Ω current limiting R, independent ON-OFF pots, 2K & 100K, 1N914 diodes, cap .0033 μF, FET, 3055V N ch.
Bernard
Joined Aug 7, 2008
5,784
Decided to ink in sketch. IC TI 555P, MOSFET Motorola sur. mt. 3055V, 60V 5A?? N ch. Operation seems rock solid. Built on solderless BB. Battery Li Fe PO4.
18,155
Any chance you could scope the waveform? I thought it might be tough to get square corners (not that it matters) at that frequency without the drive transistors on the MOSFET gate as shown in Bill's circuit which I linked to. If the OP can do a reasonable job with just a 555, all the better.
ronv
Joined Nov 12, 2008
3,770
I think you can do it with a CMOS 555 like shown. A couple of questions... Some for me and some for you. ;) The way I read the article there is no power savings but the magic is how fast the plant can respond to light and store the excess. Is that how you see it?
The LED you posted doesn't spec peak current only continuous so I assumed it is similar to others I found with a spec, so I set it up for about 800 ma.. I dawns on me that with a 1% duty cycle the average light is very small. Does this mean you will use several LEDs?
When all of the light to make the equivalent of 50 pmol photons mp2 s-' was provided during
1.5 ps pulses of 5000 pmol photons mP2 s-' followed by 148.5 ps dark periods, photosynthesis was the same​
as in continuous 50 pmol photons mP2 s-'."
Bernard
Joined Aug 7, 2008
5,784
No scope camera, RE post 25, but sides are quite straight, at pin 3 there is a 1/2 V hook on top of leading edge, trailing edge falls straight down. V waveform of FET & LED quite clean except for .2μ s, 4V peak of damped oscillation on trailing edge.
Bernard
Joined Aug 7, 2008
5,784
A logic level N ch. MOSFET would be better, the MTD3055V just marginal at 6V gate, but it was already on BB as part of DC-DC boost experiment.
18,155
Yes and no.
But now I'm wondering about those gate drive transistors in Bill's figure 10.4. If this circuit doesn't need them, what would? Maybe a bigger (or paralleled) MOSFET with a bigger capacitance?
ronv
Joined Nov 12, 2008
3,770
That's a nice FET. Low gate charge. I added the push pull driver because I was worried about trying to run a standard 555 with such a short pulse and the CMOS 555 can't drive to much.
18,155
Yes, the "surprise" I guess is that the simplified version works so well, certainly fine for the OP's application. I guess if the current and/or frequency went up, it would start to suffer.
