- Joined Jan 23, 2018
- 28,246
OK, that would not work in the US where criminal activity is protected . But adding the same high strength steel cables could certainly slow the bad actors a bit. And an adequate security system, along with enough video recording at high resolution, could assure that law enforcement could be carried out. Except in California.
Really, if all of the charging stations had a human attendant like the gas stations the bad actors could be controlled.
One other option would be to have a tube with security dye to spray the thieves when the cable was cut into. If that was done adequately they would be marked and easily identified for prosecution. Except in California where marking a criminal in the act is forbidden. ( You may have guessed that I do not think well of the way that state does things.)
