- Joined Jan 23, 2018
- 28,615
There is a large difference between welding and soldering, and a fairly big difference of brazing.
WELDING is joining materials by melting similar materials at about the melting temperature of the materials being welded. So welding can be done with just heat, or another method of liquifying the materials to be joined.
SOLDERING is a process of joining materials by bonding a different material to both metals that are to be joined. The "different material" will have a melting temperature much lower than the melting point of the materials being joined.
Brazing is similar to welding except that the joining material is an alloy including copper, which melts at a temperature much higher than solder melts at, but lower than the melting point of the metals being brazed.
