Hi, im new and sorry for my bad english, i kinda lack the specifig "terms" needed...
I have a mechanical "gearbox" with a certain part in it, "spring-loaded" and moved by gears. I want to move this part via electricity and not the gears.
Here is the part:
https://www.dropbox.com/s/8q9ucqmhkf7cqfl/20151225_204415.jpg?dl=0
Its the black plastic "plate" there with the spring below it. It moves maybe 3-5 cm backwards.
Here it is, moved at the far back where it needs to go. Other components will stop its movement, the spring will pull it back.
https://www.dropbox.com/s/ggkd1006h8aqbh7/20151225_204427.jpg?dl=0
What i need, is SOMETHING to able to pull against that spring, aprox three to four times a second. The spring is quite strong for its size, about two to three times as powerfull as pencil spring. I maybe able find a slightly less stiff spring for this aplication.
This device would be mounted OUTSIDE the gearbox and it has multiple potential locations depending on its size. Width should not be much more then the coin in the picture, more will cause problems, length is a lesser issue.
I can use for example, use piano-wire to attach the device to the plastic part, there are options. Leave that to me.
What i have:
Lipo-battery power, 3-4 cell lipo, 11.1-14.8 volts - Comparable to RC car batteries, should have enough juice to run most things.
CONTROLL CIRCUIT. The important part! I have a friend whos able to make and program a circuit to move the device, but sadly neighter of us know what to buy as the device to move that part. We have a circuit controlling the gearbox, it has room to add thigns to it.
Here is the part:
What i have:
