Need Some Pointers Regarding LTspice
elec_eng_55
Joined May 13, 2018
214
Hi:
I would like to know how to add directives for calculating ac gain for
the attached circuit.
Also, Is it necessary to constantly open the Simulator Edit mode
prior to running a sim? I have a feeling that I am missing some
step.
Thanks,
David
38,507
If you set the AC voltage of Vin to 1V and run the AC analysis, you will get a plot of the output gain versus frequency directly in dB (0dB being a gain of 1). See below:
Is it necessary to constantly open the Simulator Edit mode prior to running a sim?
No.
I run an analysis by right-clicking anywhere in the schematic and selecting "Run".
Jony130
Joined Feb 17, 2009
5,598
But we can also change the Y-axis and plot Y-axis in "linear mode"( AC voltage set to 1V)
We can do that because AC analysis doesn't take into account the power supply limitations ( AC analysis is using linearized small-signal model for all of the nonlinear devices).
Jony130
Joined Feb 17, 2009
5,598
I mean what directives do you use to obtain a graph like this?
Non
I simply set the AC analysis
Set the AC source to 1V
And run the simulation and plot the output voltage.
Then I clik right muse batton ont the vertical axis and change to use a Linear
Janis59
Joined Aug 21, 2017
1,894
RE: ""The help files for Spice are garbage.""
INTO Spice it is really like just the shortest memo and no more
For normal lead-in course You ought go to their site and download the handbook. I clearly dont remember from where I got one, but at mine is over 1000 pages of detailed explanations. I may claim it is sure too much detailed :)
elec_eng_55
Joined May 13, 2018
214
Thank you for all your replies!
DickCappels
Joined Aug 21, 2008
10,661
1,000 pages sounds comprehensive. What is the name of that manual? Was it a book you had to buy?
Some searches turned up about 150 pages and about 250 pages, but nothing like 1,000 pages.
