I'm trying to get my rgb halos to turn off and blink amber when I activate my blinker. The switchback module and rgb dimmer would allow this to work. When the blinker is activated the power to the control box gets killed and the rgb dimmer will produce amber in the halos. Only probably I'm having is the halos require a driver. Two halos each have a driver and they are in both my left and right headlights, so when blinker is activated both sides will blink. I need a switch to cut off power to the left halo and right halo while the side is blinking. See picture attached and on the halos you will see the black wire with a space where i would need switches, I just need help figuring out which switch and how to wire. Thanks.
Welcome to AAC.
MOD: Tidied your image.
Welcome to AAC.
