I need help developing / manufacturing a 12v dc timer
I am not a electronics expert, but I have tried to list details below:
12v power in (line in power protection as voltage may drop when starting the engine)
12v 5+ amp output
Button switch / magnet switch / light sensor to set mode
Mode 1 = 5 minutes off 23hr 55min
Mode 2 = 10 Minutes off 23hr 50 minutes
Mode 3 = 15 minutes off 23hr 45 minutes
Led blinks after mode set - shows current mode
This timer will be used to power a small water pump connected to a starting battery on a boat
I would like this to be as small as reasonable
Timer starts in mode 1 (or previous mode) when unit is powered on (if disconnected or power is lost)
Contact me with any information / suggestions
12v 5+ amp output
