Where did you find that schematic? I've seen lots that require LDRs, but haven't found any that sense with pv cells.... I'm understanding more every day, but can't quite get it down on paperCorrect. One of the two panel inputs needs an adjustment to compensate for unequal efficiency. 1.4 V is excellent, lots of noise margin.
There is one schematic where the two sensors are connected in inverse parallel (with current limiting resistors in your case), so when the system is pointed dead on the net sensor voltage is 0 V, and the voltage goes positive to move one way and negative for the other. That is either an industry standard way of doing things, or a bit too cute to try in your situation. I'm puttering away at a schematic.
Here is circuit using relays driven by bipolar transistors, in the way you describe.I would like to trigger a normal 5 pin spdt 12volt relay coil tested at 85ohms. Would a transistor be able to do this? And if so, how would I go about figuring which transistor would have the optimum parameters? I realize these could be loaded questions, but any help I could get would be greatly appreciated! Thanks in advance
I don't think he is using the DiseqC protocol. He is just using the motor drive.FYI: https://contest.techbriefs.com/2010/entries/sustainable-technologies/326
FWIW: DiseqC is a free antenna positioning protocol. (think satellite dishes)
You might be right, he could have used the salvaged motor.I don't think he is using the DiseqC protocol. He is just using the motor drive.
/QUOTE]
OK, you can think what you want. Do me a favor and goto the page https://contest.techbriefs.com/2010/entries/sustainable-technologies/326 and search for "diseqc" on the page and we'll talk.
He, Bryant Baker, said:OK, you can think what you want. Do me a favor and goto the page https://contest.techbriefs.com/2010/entries/sustainable-technologies/326 and search for "diseqc" on the page and we'll talk.
