All it says is made in Italy.
Thanks for your help.
John
John
Welcome to AAC.All it says is made in Italy.
John
No, it is NOT a multifunction timer because there is no function switch, only a 4 position range switch. two controls, start and reset. And that is not a guess. Two transformers inside is a bit of a puzzle, although it may be that a whole lot has not been shown to us. I did not see any wires coming from that 4 decade thumb wheel switch assembly, so who knows?It's a Multifunction Timer. Just guessing!
Here's a newer one w/ 0-999.0 min 0-99 /59 sec and so forth
https://www.bidorbuy.co.za/item/404...trol_Switch_0_999_sec_min_hr_LOCAL_STOCK.html
There appear to be ribbon cables running up to the thumbwheels, it runs to the side mounted board which has a largish DIP package on it. The secondary PS board seems to be providing (up to) ~6V to the 3.5mm jack on the rear panel.No, it is NOT a multifunction timer because there is no function switch, only a 4 position range switch. two controls, start and reset. And that is not a guess. Two transformers inside is a bit of a puzzle, although it may be that a whole lot has not been shown to us. I did not see any wires coming from that 4 decade thumb wheel switch assembly, so who knows?
