Need help identifying old capacitors from the 70's.
Kream dream
Joined Aug 28, 2017
I'm working on a pong machine from the 70's and I want to replace the caps. I'm having a hard time finding information on certain caps as it seems they changed the way to identify them many times. I'm not sure if this is the right place to post this or if this is the kind of group I think it is but I'm working on fixing old gaming electronics all the time and would love s forum to ask questions and get good feedback ( if this is not the place please direct me if you know one).
If you need more info from me just ask I'll be watching this thread.
Thanks.
dl324
Joined Mar 30, 2015
16,943
Welcome to AAC!
The last three look like they conform to the practice of specifying capacitance in pF. First two digits are the value and the third is the multiplier. 102 would be 1000pF. Letter suffix probably accuracy.
First picture has glare and not clearly focused.
That type of cap rarely fails.
30,824
152 = 1500pF = 1.5nF
102 = 1000pF = 1nF
104 = 100000pF = 100nF = 0.1μF
473 = 47000pF = 47nF = 0.047μF
The last two appear to be mylar capacitors.
As dl324 suggests, I would not bother to replace any of those capacitors. They are not likely to fail.
GopherT
Joined Nov 23, 2012
8,009
Thanks.
They are about $0.05/ea.
http://www.taydaelectronics.com/capacitors/polyester-mylar-film-capacitors.html
Hypatia's Protege
Joined Mar 1, 2015
3,228
Re: the capacitors shown in the images - Unless you have reason to believe they've suffered electrical abuse (CIP 'over voltage') - no need to bother...:cool: Polymer film Caps appropriately applied to decoupling and small signal AF almost never degrade or fail with use/time...
That said, 'preemptive recapping' of all electrolytic Caps is a highly recommended initial step of any restoration project:)
Best regards and good luck!
HP:)
recklessrog
Joined May 23, 2013
985
When we were children, we had trouble with rats. A neighbour modified a mouse trap to not only try and catch the little blighters, but wired a pair of contacts to the trap that would complete a circuit from the live mains to a an old metal cased sealed electrolytic capacitor. In those days, the 240 Volt 15 Amp plugs and sockets were not individually fused, only at the fuse box which he had wired up with thick garden wire.
We were all awakened a few nights later by the arrival of the fire brigade who after dowsing the fire that had been started in his shed, retrieved a decapitated large rat covered in what looked like a severe case of dandruff, being the innards of the capacitor which had exploded with considerable force!!!
The neighbour was suitably reprimanded by the fire chief, and a few days later our local exterminator came round and put highly toxic poison (Arsenic?) down. This resulted in the death of at least two cats and a dog and the hospitalisation of one small child.
I don't think the rat problem was cured until the area was bulldozed and a new housing estate was built there!!
PhilTilson
Joined Nov 29, 2009
131
PhilTilson
Joined Nov 29, 2009
131
That puts me in mind of an incident in the 1950s. I was about six years old and we had gone as a family to the cinema the night before to see Walt Disney's Snow White and the Seven Dwarves.
As one did in those days (and probably still do!) my sister and I were 'acting it out' the following morning; I was the wicked witch. For some obscure reason, it seemed a good idea to try to create a 'spell' by plugging my older brother's crystal set headphones into the 240V, 15 Amp, unshuttered power point. Well, it certainly created a flash and a bang! - but I seem to remember my brother being puzzled as to why he couldn't listen to The Goon Show that evening...
leeleduc
Joined Oct 9, 2008
Thanks.
Capacitor code table
http://kaizerpowerelectronics.dk/theory/capacitor-code-table/
