I can't identifying VD196 possible product of Texas Instruments.
Somebody can help.
Somebody can help.
That is perhaps the most meaningless answer you could have given. Am I supposed to have a clue about some random manufacturer's naming and numbering scheme? Who made it and what is it for would help determine if there is a high probability that it uses a custom chip.ECU VDO 0215456832 , Board no.992655702
You're right -- I don't have access to the same references that you do. Even so the TS could have made a more helpful post by saying that it was an ECU module from a Mercedes. Then I would have told him the same thing, that information on custom chips is very hard to come by.Not true @Papabravo, the manufacturer VDO and the part number is sufficient information for reference. Just because you do not recognize the ecu number or components involved does not mean someone else does not. I happen to repair ecu's everyday and know many masked chips. Unfortunately for TS I do not recognize this one at the moment but I may have it buried somewhere in my notes. Granted AAC is not the best forum for ecu repair but I do know there are a few guys here that do it.
A better question is why do you think this IC is bad, and from what you can tell, what is the function of it?
An interesting observation. For 13 years I've been ripping posters for confidentiality requirements that are almost always a dead giveaway to people who have no idea what they are doing. I'm a big believer in Don Lancaster's approach that your idea needs to be published first and frequently to establish you as a bona fide expert. Nobody ever got rich off of a single idea. Ideas are not gold, "they are worth less than a dime a bale in ten bale lots." Many people have gotten rich from a flood of ideas which were turned into enterprises.Very true. The more information provided, the better it is to help someone. New posters always treat information like its gold and can not stand to give it away for some reason .
