Hi all, I hope some clever minds can help me decipher a circuit and work out what's going on to hopefully reengineer parts to make a project work. That's a mouthful lol
So basically to sum it up, in my car I have a reverse camera that works perfectly on the stock head unit however on a replacement head unit that uses a standard RCA jack the picture quality is worse.
This is a simple case of the signal type being wrong for the input type on the new head unit but I need to work out how to convert it correctly.
I have taken apart the old head unit to try and work out what's going on but my electronic knowledge is limited. From what I can see it seems that the input signal is of a balanced type and I believe the original head unit has some sort of balun or what I believe is prob more likely is it uses some sort of differential signalling and there is a receiver that I need to replicate.
I have attached some pictures
So at the bottom is the input (direct from the camera), I've labelled up the 2 input wires and these also have a third shielding wire I haven't labelled
These go through a resistor and capacitor network into an unknown chip labelled "LMW37". This chip has the 2 input pins, a ground and a 4th pin. The 4th pin goes through a couple resistors and then I have marked it as "output". There is 3.3v supplied at this point. I have also attached a picture of the opposite side of the board and circled in red where I get continuity from where I have marked "output" and this goes into this other IC which I guess supplies the 3.3v
I hope someone can take a look and at least steer me in the right direction, I really need to know what this "LMW37" is and what it's function is as I believe it is the key to working this out and getting the useable stable signal that I need for the new head unit.
Thanks in advance
Thanks in advance
