AlbertHall
- Joined Jun 4, 2014
- 12,625
For future reference, if I ask you to measure a voltage the board should be switched on. If I ask you to measure a resistance then the board should be off. This is a general rule for using the meter. If you measure a place which has voltage with the meter on a resistance range you might damage the meter or the board.
