Need help finding the resistor size for a simple circuit (Ohm's law)
gandoN9
Joined Oct 12, 2020
18
I know there is a serial and parallel circuit
I know R1 = 2k, R3 = 1k and i know Vout which is 1V. And i know 5V is coming from supply. I need to calculate the size of resistor R2.
I can calculate :
1) IR1 = 5-1V/2000ohms = 2mA
2) UR1 = 0,002A*2000ohms=4V voltage drop on R1
How do i go on finding R2?
Can somebody explain me with exact equations to calculate R2, and currents which run trough resistors (step by step please)
Help will be much appreciated!
Martin_R
Joined Aug 28, 2019
137
Hi, you've calculated the current through R1, you know the voltage across R3, and its value, so the current through it can be calculated. So now you know what current remains for R2, and the voltage across it. Ohms law is your friend.
Martin already provided a way to solve it. I will provide another.
You know that the voltage drop over R2 and R3 is Vout (1V).
The current through the equivalent resistance (Req, R2 in parallel with R3) is the same as IR1.
Calculate Req using ohm's law.
But Req is also the parallel of R2 and R3.
Now you know Req and R3. Calculate R2.
Wolframore
Joined Jan 21, 2019
2,619
Simple voltage divider, answer is really simple. Now why? It can easily be done in your head.
Divide this into two problems
1. what does total resistance of R2 and R3 need to be to get 1V at Vout? Hint think of R2 and R3 as one resistor. What is this value?
2. what is R2 when R2 II R3 must equal value discovered above?
Then finally calculate current flowing through each resistor. You can actually go backwards using current to deduce the resistance using Ohms Law or Kirchhoff... it’s just simple division and multiplication.
MrAl
Joined Jun 17, 2014
13,791
I can calculate :
Here is the drawing cleaned up to hopefully make it easier to read.
A clear image makes it easier for members to help with the problem.
