Need help finding a specific PCB type.
Shiv Kumar Sharma
Joined Nov 16, 2017
6
I am searching for some perfboards which have "Connectors" just like a "PC-RAM" does. And a similar socket to go along with it.
What I intend to do is create any N-number of Modules, which then I can plug into compatible sockets; thus stacking them on a Board.
Thanks.
Shiv Kumar Sharma
Joined Nov 16, 2017
6
What kind of "PC-RAM"? DDR2, DDR3? The old DIP socket type? I am afraid you ar going to have to make your own by buying the connectors and sockets and wiring it up.
Actually i am hoping for someone to direct me. I'm unable to come up with anything on google search.
I can source sockets.... but what to do about the connectors? I am not sure if the perboard (with connectors on either side) would fit in or not.
spinnaker
Joined Oct 29, 2009
7,835
Now that's what i'm talking bout! Any suggestion for a socket to go along with it?
You need to be more specific. What kind of socket? There are thousands? Do you mean a socket for the board Albert posted? If so they are called edge connectors. You would want females to match the male boards.
https://www.ebay.com/itm/Cinch-50-44A-30-44-Pin-22-Position-Comm-Card-Edge-Connector-2pcs/401394472154?epid=1610922808&hash=item5d74f994da:g:y3AAAOSwr2ZZpwEc
You will need to make sure the number of pins on the board matches the connector.
Shiv Kumar Sharma
Joined Nov 16, 2017
6
Okay. If i'm unable to find the size i can always break the board.
And i think (after enlightenment), Edge boards and connectors are what i am looking for. Fits the purpose. Thanks.
